We have the ability to localize the names on attributes for other languages, but if you need to store values in different languages you have to create multiple attributes and figure out some way to mange them all. I would like the ability to have localized values for any attribute, as well as set a master language as default and required. For instance the Description, you could have the value in 3 different languages and depending on the users language preferences, it would display the respective value. Other users would not see the alternate languages except when editing attributes. Setting the master language would be setting the required condition on the attribute for a particular localization, allowing you to set a company standard language and still accommodate local languages. If a non-master language was populated it would force the master to also be, before it would allow submission.
