The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Add option that will allow/prevent a saved search from immediately executing when selected. This will allow the user to enter the info in only the criteria they want THEN perform the search
Add option that will allow/prevent a saved search from immediately executing when selected. This then allows the user to enter the info in only the criteria they want THEN perform the search. This behavior was possible in 9.1.
Because he said it better than I can the following is shamelessy snarfed from Stephen Galayda's post: http://portal.ptcuser.org/p/fo/st/topic=16&post=115685 :
"I want to create one search that includes several different possible Criteria.  However, the user could use any one, a few or all of them.  I also don't want it to start the search automatically.  I want the user to pick on the saved search, enter the info in only the criteria they want THEN perform the search.  The problem is if I set one of the attributes as Required then the user can't use that saved search if that required criteria is not what they are looking for."
This option could be a check box in the "Advanced Options" dialog like the following:
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
