Add possibility to get PTC_WM_PART_NAME and PTC_WM_PART_NUMBER to epm documents for use in CAD
We really need to use the parameters
PTC_WM_PART_NUMBER and
PTC_WM_PART_NAME
in our Creo Parametric CAD models in order to show the reference of the parts they belong to!
This would be highly useful and also productive from a data management point of view since it would decrease the possibilities of confusion for non-advanced users etc. but also decrease the workhours required to verify if the numbers we display on the drawings are correct...
There seems to be much demand for this as shown per
http://communities.ptc.com/message/181114
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS18803
and others....
A rough guide to do this is even included in the Windchill Customization Guide or the Guide Using Creo with Windchill.
And last but not least the names of these parameters can be set by the Windchill preferences
Part Name System Attribute and
Part Number System Attribute .
As we see in https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS99481 this is already possible if you are using Creo Elements/Direct!
Dear PTC, please add the possibility to get these parameters working into Creo Parametric without costly customizing !
greetings
8 Comments
GregoryPERASSO
Hello
It is also OOTB for Catia V5 workgroupmanager if I remember ....
we implement the custo as specified in Custo Guide.  Even if I prefer that PTC implement my idea for watermarking enhancement.
Cause the WTPart is the central object in Windchill Data Model. And duplicate information between objects can lead to complicated use case ...
And since 10.1M030, we can associate multi owner WTPart to one CADDocument.... so from which one synch the attributes ... (both ...)
regards
PTCModerator
Emeritus
Status changed to: Under Consideration
arne_vn
6-Contributor
Still open, and very much wanted.
We resolve this now with customisation.
For solidworks, PTC_WM_PART_NUMBER is pushed by default in the properties of the CAD doc. Hard to explain this...
SteveShaw
Status changed to: Implementation In Progress
Projects to support this request is currently in development for Creo 6 and will require Windchill 11.1 M020 or higher as there is a dependency on a preference setting to configure which system attributes to pass.
JoshuaHouser
So Creo 6 is in Production, but I haven't seen any decent documentation on the usage or requirements. Am I missing something? Specifically interested in the item where @SteveShaw mentions it will require WC 11.1 M020 or higher.
SteveShaw
@JoshuaHouser this new capability in Creo 6 is dependent on setting up in preferences using Windchill Workgroup Manager > Mapping System Attributes and File Properties which supports configuring for the Creo authoring application starting in Windchill 11.1 M020 and beyond, as depicted in the image below:
JoshuaHouser
Thank you!
SteveShaw
Status changed to: Delivered
Support for these specific attributes has been delivered.
