The Thumbnail Navigator displays out of the box all versions (revision.iteration) of "where used" objects.
In case there are some hundred of versions of the same object in the report it makes the whole display unusable. The information the designer is usually looking for is the object names - not the exact version - this is something he can get from the "Where Used" tab on the Object Info Page.
We would like to have a preference to control the behaviour of the Thumbnail Navigator "Where USed" and limit the report to only show the latest version of "Where Used" objects.
