Add "As a Structure" view and "Export List to ..." to managed baselines
As a developer of Dynamic Documents and someone who is accustomed to a Structure view for MIL-STD books and DITA bookmaps, it would be ideal if baselines would display the same "As a Structure" view that was available when collecting the dependents to add to the baseline. If the primary object is a book, bookmap, map, or an object that has a dependent, then the user should be able to view the baseline in a Structured View.  The user should also be able to export that baseline as the structured view to XLSX or other choices.  Allow the user to customize the columns available in Structured View to be exported with desired data.
6 Comments
BobWBristolRI
3-Visitor
Endorse. Much needed.
mnaturale
3-Visitor
I vote yes on this.
baptistaj
3-Visitor
@dswatson how do we get some eyes on this enhancement request??
lgrant
We need this. We are creating baselines to capture a design intent. Then use that as a configuration for a downstream view for manufacturing.
BB_8720586
2-Guest
As well as be able to export with previous revs as Baselines kept for reporting and history don't want the most recent revision. Also seeing as the Baseline functionality allows for you to update your Baseline with previous revs, the export should export with the revs from the Baseline itself, not the most recent rev within Windchill.
olivierlp
Community Manager
Status changed to: Archived
