Adding the "Edit Multiple Objects" to Resulting Objects "Actions" drop down menu of a CA would help significantly when doing mass changes to WTParts. The Change Activity (or ECN) is an obvious place where mass changes to the WTPart attributes would be occurring. Not sure why it is not there already, as this drop down already has "mass change" (which is great), but it is for structure changes only. Why not complete the convenience and allow mass change to WTPart attributes? This sure seems like a relatively simple change that would facilitate changes, especially when a large amount of objects are involved!
VOTE IT UP! Is there any reason not to?
