Adding the ability to batch print the content of a package would provide a significant efficiency, especially in the case of Work Order packages where drawings and WIs are regularly printed to be used on the shop floor or out in the field. There would need to be some sort of control to ensure that a filter of the object list could be applied even if it was just was on checkbox selection or similar.
