In Windchill, it's possible to rename articles and CAD document, but not other kind of documents.
This might be a very good feature and will also harmonize the interface in using a similar process for all kind of objects within Windchill. It doesn't really make sense that we can use this feature for only a part of the available objets.
At the moment, we have the following text explaining this can't be done on objects other than Article and CAD documents :
