Description of problem:
When objects are added to workspace via the collector all selected objects are filtered together. For our business we need library parts to always be added as latest, not As-Stored or Released. This causes massive add to workspace conflicts forcing any number of lengthy work arounds for the user. Who simply wanted some assemblies added to a workspace. Instead the designer is bombarded with conflict after conflict, many times the only solution is to remove offending objects and their children one by one (which is an unacceptable method to resolve)
Proposed solution:
Add the ability in the "filters" to set ATW criteria by multiple contexts. This would allow a user to add to workspace all design objects with one set of rules (perhaps "As Stored") and a second set of library parts with another set of rules (Latest). This will eliminate most conflicts allowing a user to quickly ATW.
