Add to worksapce configuration: As stored + latest iteration
0 Kudos
due to history setting, we use sometimes revision to represent alternative.
It means, we must always use "as stored" filter to load the correct revision on workspace.
but on the same time, only the "latest iteration" in the same revision should be used.
so we would like to use "Revision from As stored" + "last Iteration".
  1. OOTB there is already an Attribut "last" on the structure view of common space.but we don't have it on workspace. the idea is to have also this one on workspace / or even better to have a loading rule "As stored Revision + latest Iteration of this revision"
1 Comment
olivierlp
Community Manager
Status changed to: Archived
