When adding multiple documents via desktop integration into a defined folder in PDMLink (Windchill) the documents are automatically placed into the default configuration folder (documents in our case). They should be loaded into the folder that I added them to in explorer. If I add a single file it adds it to the right folder but multiple goes back to the default folder. This is very inconsistent and if I want to load all of my requirement documents I have to add them to the base folder and then move them all.
