I would like to remove or gray out "Revise and checkout" action because it doesn't display the collector UI.
It is now possible to hide the 'Revise and Checkout' command in Creo Parametric 5.0.
http://support.ptc.com/help/creo/creo_pma/usascii/#page/whats_new_pma%2FdatamangementHideReview.html...
