- As others Windchill java Applet, need to go to Web UI
-being able to define MBAs, IBAs columns, views and sort columns as in any Windchill table
-add a key word search like in other windchill table
-add some new actions (only add and remove component in the applet):
-add the import from excel action (export actio already exists)
-Support the new Windchill 10 advanced Filter ConfigSpec (notably Alternate BOMs) - cause there's only Views in the applet so impossible to modify Alternates mBOMs
-ability to modify any attributes or IBAs of the part usage link (today only the quantity): line number, quantity, unit, to be built (if a CAd is associated), etc ...
- ability to use the Advanced assembly editor from the Change Notice mass action menu
