Revise Engineering and all plant views same time on a Change
Apply Smart logic to recommend next possible revision upon revise using described by links and CAD links. Example, if part revision is B, described drawing revision is F then recommended part revision upon next revise should be G but not C.
There are few more use cases that need to be accounted in the revise logic
