Hello
The advanced Search delivers incorrect results when Last Modified On is used as Criteria and All Type as reported in the following article - CS267335 https://www.ptc.com/fr/support/article?n=CS267335&language=en&posno=1&q=SPR%206839897&source=search
The idea is to correct the bug and make the criteria Last Modified working properly without selecting a sub-type.
Regards
