Affected / Resulting Objects in Change Notice
I expect windchill can check and can't submit if Affected Objects  and resulting objects is the same object in change notice.
4 Comments
GregoryPERASSO
Hello
easy to customize in the Workflow, wizard step validator, or may be in the new validation rules in 10.1...
But you're right ... it should be out of the box
regards
JoePriest
7-Bedrock
I don't agree that this should be OOTB.  If anything it should be preference controlled.  We have use cases where we need to do this.
GregoryPERASSO
Agree Joe ,   with a preference.
What about your use case ?  To set effectivities on an already Releaesd part, but in a new Product context ?
regards
PTCModerator
Emeritus
Status changed to: Archived
