After starting Auto-Execution Project one cannot Import Plan in Windchill ProjectLink
Hi ,
I am using WIndchill 11.0 M010 Project Link, however i want to import an *.xml plan after starting a Project in Auto Execution Mode.
I want to suspend and Import a plan. Currently there is no functionality available. which was also confirmed by PTC TS. Refer Article CS65724(https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS65724)
As a customer rof PTC, using Project i feel this is an essential for quick changes in Project plan using a *.xml plan
Thanks & Best Regards,
Amit Khazanchi
2 Comments
PetrP
We also need to stop autoexec project, import slightly changed plan and continue running as autoexec. You can import plan only into manual projects or autoexec ones before it is started (crazy is WCH recalculate autoexec project start to current date anyway).
olivierlp
Community Manager
Status changed to: Archived
