The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Allocate more than one operated on WTPart (with unit set to each)
During the creation of MPMLink Process Plans there is a possibility to add allocated on WTParts.
With the unit set to each, the representation of the WTPart will also be loaded to the illustration.
Currently it is possible to allocate only 1 WTPart with the unit each.
To allocate the same WTPart twice (or more) the user has to add a separate occurrence (new line to the table).
This way the Allocated On table will be overpopulated with the same WTPart occurrence.
The idea is to have the possibility to edit the quantity for Allocated On WTParts (with unit set to each) and have the correct number of representations loaded for illustration purposes.
For more information refer to PTC Support case CS289345 and SPR7635429.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
