Allow BOM compare between "Assigned Usage Expressions" and/or "Assigned Occurrence Expressions"
When creating EBOMs in PDMLink by adding/changing options in the "assigned usage expressions" or "assigned occurrence expressions". I would like to be able to compare the old EBOM to the new EBOM and check the differences between the two.
Currently BOM compare does not check for differences in the expressions.
Out of the box BOM compare will not show the differences between "Assigned Usage Expressions" or "Assigned Occurrence Expressions".
1 Comment
olivierlp
Community Manager
Status changed to: Archived
