Background:
We have recently deployed WTParts on a PDMLink system with 25+ years of CAD Documents in it. Many CAD Documents are unpublished. The WTParts need to be audited and frequently edited. Once attributes have been updated, the WTPart needs to be republished which currently can only be done one-by-one by hand or by an administrator running a batch publishing job after hours.
We want:
1. to be able to select a range of CAD Document objects or WTParts from a set of Search results or a context folder table and send them to the publisher immediately.
2. the ability to collect associated Parts or CAD Documents so they can be published together
3. to be able to set a priority property so that it goes to either the L, M or H queues per the site requirements
