Currently, if you use the Solidworks (for example) WGM to check data into Windchill, you will need Solidworks to be installed on the CAD worker machine to create Creo View or Windchill viewable data, for example in thumbnails or in the PSB.
As Creo is capable of opening Solidworks, Inventor, NX etc. parts, we should be able to use the single Creo license (PROE_FoundationVis) to create the viewables (and maybe also the .creo wrapper files to improve the file opening performance in Creo).
This would remove the need to maintain separate licenses for other CAD packages, especially where those packages are considered legacy systems.
