Currently when you implement a new DataUtility (com.ptc.core.components.descriptor.DataUtility) it will NOT render on Multi Create/Edit Part and Document screens. According to PTC this is not supported at this time. The only way around this at this is to modify PTC's OOTB files to render a custom input component (like a suggest text box). From and end user perspective its difficult for them to see different input components between a single Part/Doc create and a multi Part/Doc create.
