Windchill does not currently allow interaction or modification of the primary content file's <file_name> in an Object Initialization Rule (OIR) when creating a new WTDocument. I would like to be able to read, modify and change this value in an OIR.
Comparing WTDocument to EPMDocument, you can see many more capabilities available for EPMDocument vs. WTDocument (such as File Name). Where feasible, the attributes, layouts and capabilities for these two type of object should be as similar as possible.
I have a few examples to demonstrate the need.
Someone may have work-arounds or customizations to support this, so please comment if you do. I would be interested to hear or any alternate ways to achieve these use cases.
Other related Ideas to consider.
