If a search is conducted with the type set to CADdocument then user defined attributes can be displayed in the results table. If the same search is conducted with the type set to all then the user defined attribute column does not display.
Suggestion is to allow the attribute column to to displayed and populated for objects that have the attribute and ignored for objects that do not regardless of object type searched for.
