Allow WQS FRACAS Graph to create a target line automatically according to system tree items data field.
0 Kudos
When use the ‘The results of a calculation over time’ FRACAS Graph type, the users hope that a target line (a horizontal parallel to X axis) can be created for comparing with the MTBF or failure rate. At present, we need inputting the target data for every month through ‘Edit Graph Data’. If there is any way to create a target line directly by the data field from system tree, it will reduce the repetition operation.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
