Allow assign Option Sets by users
In Options & Variants, after creating an Option Set this has to be assigned to a configurable part.
Currently, only the Product Manager or Library Manager can do this, due to hardcoding.
(Support call identified function 'hasAcessToAssignUnassign' which is called by 'OptionSetRegisterActionsFilter')
In this function, it specifically (hardcoded) requires Product Manager or Library Manager.
However, in normal business conditions this role (Product/ Library manager) has alot more access and permissions / abilities than the user who would be doing the work under Options and Variants. We cannot just make all these users now also Product Manager.
There is a role called "Option Manager" that we should be able to use here also.
My request is as follows:
1. Please transform this ability to either an access rule that we can adjust, or at least a site/ org preference where we can specify another role.
If this is not achievable, then at least #2 below.
2. Add the role 'Option Manager' to the hardcoding since that role already has many other abilities under the "Options and Variants" heading.
3 Comments
DomenicLaritz
Rivan, you should vote up your own idea!
And because you forgot it, please vote up that one too:
When creating a new product idea, it automatically adds a positive vote for the creator.
RivanHassanali
1-Newbie
Hah, thanks
PTCModerator
Emeritus
Status changed to: Archived
