When revising an assembly or part from Workspace, its not possible inside the "revise window" to directly check-out the newly revised components . Its annoying for users because they have to go back to the workspace, reselect the revised elements, and put the checkout lock on them...
Maybe it wont be very difficult to implement as a similar action already exist in Creo Parametric session actions (right clic => Revise & Checkout) :
Can you please add a "checkout button" applicable for newly revised object inside the "revise window"?
Thanks in advance
