Allow column widths to be set in Windchill
Allow column widths to be set/remembered in Windchill.
Currently in search view, rename, object information, etc. columns revert to the default size after each update of info; whether switching to a new object or adding additional related objects to the table.
Allowing both column widths to be set to a default and remembering the user's preference would save time endlessly resizing columns in order to view the data.
9 Comments
JeffZemsky
For PSB we are looking at this for the next release
dhermosillo
Which release is that, 10.1 Mxxx or 10.2 Mxxx?
SvenR
I have to add: it would be fantastic if column widths would be preserved/saved in the workspace table views.
Right now it drives us a bit crazy to resize them every day because they are too wide and take up too much space on the screen.
I went throught exporting the table views, and the width of the columns has a setting in those XML files, but it is '0' all over. When exporting another table view from within Windchill, there are real values that are in the generated XML.
So it seems that the functions are almost there, but they didnt reach the workspace table views...
Hr.Tox
6-Contributor
Hello PTC,
we still see this issue in 10.2 M020.
If the table view in a workspace is changed it resets column size of this table view.
Please see PTC-Call CS31693 too.
Any comments here?
smerampichaiah
1-Newbie
Will this be applicable for FlexPLM? This is very much needed for FlexPLM Bill Of Material
STEVEG
20-Turquoise
Since this is marked as Implementation In Progress I wonder what version it's being considered for.
Tmetcalf
Emeritus
Sorry for the messaging everyone - please continue voting here Column width in the workspace
PTCModerator
Emeritus
Status changed to: Current Functionality
kotlownia
7-Bedrock
@Jaime_Lee  This idea was marked incorrectly as Current Functionality. The idea that the other PTC employee linked only mentioned the workspace columns and that got resolved. This idea was about search view, rename and object information columns. The views in those tables still don't have the disc save option.
