In many customer FRACAS and FMEA implementations, it is asked if we support linking to other records. For example, customers would like to link related incidents together. Outside of the standard one-to-many and many-to-many relationships, we do not.
This need could be met by adding a property to text and memo fields in the Data Definition file to use the field as a link to a record in a user-selected table. The field could display in the system as a normal record selection control, but maybe after a selection has been made, clicking on the linked field could take the user to the linked record. This would be a flexible way to handle many linking requirements.
