Allow merging of deleted instances into family table generic for SolidWorks
0 Kudos
Currently it is not possible to merge a standalone part as an instance of an existing family table for SolidWorks-WGM interaction. For Creo this is not a problem.
The reason for having the ability to merge a standalone part into a a family table these part might be accidentally converted into a standalone part or due to incompatible family table issue, this allow user or windchill admin to "fix" the problem.
2 Comments
Sierra
3-Visitor
This has been solved (at least in WC 11)
Let's go for the worst case:
An instance has been deleted from a family and you are wanting to add it back.
1) Save a file under the instance number
2) You will get a conflict. Update and re-use/keep the file in your workspace
3) Check In
4) Open generic of family that you are wanting to re-add instance. Create configuration with same number as the instance checked in of step 3, ensure PTC_IS_INSTANCE=Yes. Save, but DO NOT CHECK OUT.
5) You will get a conflict. Update and re-use/keep the file in your workspace.
6) YOU MUST NOW UPLOAD THE FAMILY TABLE.
7) Check out family table.
😎 Check In family table.
olivierlp
Community Manager
Status changed to: Archived
