The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Allow multi-value attribute to be display in office document using DTI
when an attributes has multiple values, in office document using DTI, it will only shows the first value. The rest of the value is considered as separate field in office document
3 Comments
sm
1-Newbie
1-Newbie
Jeong Ming Foo‌ can you describe what is expected in Windchill DTI when referencing a multi-value attribute in more detail? Maybe an example? I am assuming you are looking for the ability to see all the possible values and chose one from a pre-populated list when setting the attribute value?
jfoo
6-Contributor
Hi Scott,
I would like all the attribute values to be shown in the shown in the office document. For example, if the WTDoc attribute initially has one value 'A'. this value will show in Word with not problem. If you update the attribute to three values 'B', 'C' and 'D'. Currently, when opening the Word document, none of the updated value is shown. it will still show 'A' rather than showing 'B', 'C' and 'D'
I would expect regardless how many values the attribute contain, Word will display all the values in the attribute.
olivierlp
Community Manager
Status changed to: Archived
