Allow preference on "Publish to CAD after checkin" to be set per user
0 Kudos
Some of our users are mechanical and use Creo Parametric to design products. For these users it is important for the preference "Publish to CAD after checkin" to be turned on. Our electrical users also create parts, but with no linked EPM Document, so having the check box ticked on checkin causes the event manager to report an error.
It would be ideal, therefore, for the preference described in the following article to be available on a per user basis, rather than only available system wide.
https://www.ptc.com/en/support/article/CS332900?language=en
3 Comments
ScottMorris
This seems like a mute point now that ECAD WGM is deprecated, but could be a nice addition if it is honored in the RestAPI
Chris_Johnson
In our case, we have the mechanical CAD designers, who use Creo Parametric, so having this option selected is useful, and electrical designers, who use a totally disconnected system and manage their data manually using WTDocuments and create WTParts and structures manually. In this case, there is no CAD to update, so the event manager simply returns an error if the box is left checked. This is annoying for the electrical designers.
olivierlp
Community Manager
Status changed to: Archived
