currently when publishing office document containing Windchill attribute (eg: version, lifecycle state), the published PDF does not display the updated Windchill attribute value. As a result, the published office PDF does not reflect the correct Windchill information.
eg: A Word document contain a field linking to Windchill version attribute. This document at version "1.1". When checkin, the document iterate to version "1.2". The publsihed PDF for document version "1.2" is showing version "1.1" rather than "1.2".
