When publishing large amounts of content and need to capture a report, being able to select items in the WVS Job Monitor and export them to an Excel spreadsheet will be very helpful. The user can use the current search options provided in the WVS Job Monitor to filter to the desired items. The save action would be similar to that used for the Search results Actions->Export List to File.
