There is currently no way to identify all tasks assigned to a particular user. None of the native reports provide this data, and the search tool does not recognize Assignee as a searchable attribute.
When an employee leaves the company, I have no way of identifying which active changes were assigned to that person without opening them all individually.
When changes are experiencing delays in completion, the Windchill administrator needs to be able to determine if the delays are due to particular users or if the delays are global.
I request that the following attributes be added to the search parameters:
1. Task Assignee
2. Task Reviewer
3. Auditor
