Allow to leave an existing (older revision/iteration) object in the workspace, if a assembly with a newer revision of this object needs to add to the same workspace.
At the moment it is only possible to "substitute the existing object in the workspace" but it is not possible to "keep the existing object".
The dialog should be expanded with the option to "keep the existing object" in the workspace.
