Allow to use twice the same join model in a given report template
0 Kudos
Currently it is not possible technically to use twice the same join model in a given report template.
This case can happen in the same way that you would need to use twice a given table.
For instance if you need to get information, which are on different lines in the database table, on the same line in the report, you need to use twice the table and join them someway.
We experienced this on a FlexPLM project when trying to display Material's effectivity prices on a given line in the report while they were stored on different lines in a join model.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
