Allow using different symbols / icons for different View Versions of WTPart
A WTPart can have different view versions (e.g. Design View, Manufacturing View, Reduced View, etc.).
To be able to differentiate the view versions better and to avoid selecting the wrong ones (e.g. in the Resulting Objects of a Change Notice...), these should have different icons.
It becomes even more complex / confusing if you work also with different WTPart subtypes and you have for each subtype the possibility to have the different view versions. Therefore a different icon / marker in the icon for different view versions would be helpful.
3 Comments
Level 2
Great idea. As a company may use several different views it may make sense to have a preference where you can define the article's view markup. E.g. if you just add a simple colored dot in the upper right corner of the article's icon you should be able to define the colors of the dots belonging to a specific view in a preference.
Level 12
Status changed to: Current Functionality
This can be supported by utilizing the Icon Delegate functionality today
Icon Delegates
Level 8
Thank you for the information @JeffZemsky.
Could you please update the PTC Article CS293510 with this information?
Thank you very much.
Daniel
