Annotations on Representations should always copy forward
Per PTC’s help site, representations can be “copied forward when parts iterate, as long as it does not compromise the validity of data published from EPM data”.  However, they not iterate what is valid and what’s not.
PTC please publish the rules for copying forward annotations, so we can make sure they always copy forward.
2 Comments
GregoryPERASSO
publish.copyrepresentationsforward Default Value: true
Synopsis: Copy representations forward.
Description: Allow Representations to be copied forward when parts iterate, as long as it does not compromise the validity of data published from EPM data.
publish.copyrepresentationsforward.restrict Default Value: true
Synopsis: Restricted mode for copy representations forward.
Description: Restricted representation copy forward mode will not copy a published representation forward when a WTPart iterates and old and new iterations point to the same EPMDocument.
we set the second to false. As when a wtparts iterates alone, it does not compronise our CAd part (no WTPart attributes synchronised)
PTCModerator
Emeritus
Status changed to: Archived
