The new as-matured configuration resolution is great, it saves the need to create lots of baselines.
Some type of users will have the need to always acces the BOM information using this filter. At the moment they have to manually set it by hand for each of their structure.
If they try to save it as a customized saved filter, the filter will retain the as-matured date definition of the object for which the filter has been defined first.
We should be able to have a predefined filter to access this as-matured view that updates automatically accordingly to the active object. If we can save it in such a dynamic way, we will also be able to use it in PTC Navigate View which would be really useful.
