Assign item expressions on multiple objects
Possibility to select multiple objects on the structure tab and assign item expression to these objects. Function is greyed out if more then one object is selected.
3 Comments
stouret
6-Contributor
this is possible with MPSE but not with MAPSB....
Chris_Johnson
This is something we would be very interested in, especially in the MAPSB. Often our MBOMs bear very little resemblance to our EBOMs, so being able to apply the expressions to all of the parts within an assembly would help us synchronise the option choices between the two.
yley
7-Bedrock
That would be great to have this feature as well in both PSB (PDMLink) and MAPSP, PPSB to assign expressions on multiple part usage links and/or occurence links:
EBOM (PSB)EBOM (PSB)   Process Plan BrowserProcess Plan Browser
