Auto Populating Mount PATH For New Host
Situation: In Cluster environment, one of the method of configuring vault is to   create individual host name for each node in the cluster.  During first configuration, it is fine to configure mounts for each host manually  but when we Add a new node to the existing cluster environment,  then we need to create a new host in vault administrator ..  after that we need to update all mount paths manually ..
Problem:   Updating Mount path manually  for each entry for the new host.   it would be very tedious if the count of folders is huge say 250 or 300 and time consuming also.
Solution:  The idea is very simple,  AUTO populating the mount path values.  This is achievable because,   mount path for other host name is already present so we can use the same value for populating new mount path for new host.
Some facility should be given to mouth large count of folders by code.
Hope problem and solution is clear.
Regards
Manoj
1 Comment
olivierlp
Community Manager
Status changed to: Archived
