Hello!
We'd like to have the ability to autoattach a generated PVZ as secondary content to a c3di-file.
Background:
When creating c3di-files with Creo Illustrate, we check them directly into the Information Structure.
A PVZ is created as representation with a publish rule.
When now authoring XML-files in Arbortext Editor, we need to use the PVZ file. This however, is not present in the information structure.
To be able to use a c3di-file in combination with the graphic_fallback-feature in Arbortext Editor, the c3di-file requires a PVZ as secondary content attached. This however can - as fas as we know - be only be done manually.
So we'd like to have an enhancement to the publishing process, where we can tell the WVS to attach the generated PVZ directly as secondary content to the c3di-file. This would make handling of the files much more easier.
Thank you,
your Windchill Team @ DATACOPY.
