Autodesk Inventor migrated Files mass import in Windchill.
0 Kudos
IDEA:
Because Autodesk Task Scheduler doesn't work with Windchill PDMLink,  We would like to have a 'mass import' feature in order to override and check-out lots of CAD Docs in once.
Following the procedure
 1. Add all CAD Docs  to the WS
 2. Mass Import the new objects  from local disk which will prompt you to override and checkout the files
 3. then check-in all objects
1 Comment
olivierlp
Community Manager
Status changed to: Archived
