Hi
we all know that vaults get full and every so often a new vault must be created. When implementing a brand new server it is possible to automate this creation and set a limit for the number of files the vaults should have.
As far as I know, if this automation process is not enabled during the implementation it is not possible to enable it afterward.
The idea is to enable this in new releases of PDMLink.
This will provide administrator with great flexibilities.
