Automatic deletion of existing representations when triggering new publish job
Dear all,
Based on recent project experiences at Thyssenkrupp Inustrial Solutions, it would be really useful to get the mentioned capability OOTB, without the need of customization, and to control it through property/preference.
In a “republish at metadata change” scenario, a new publish job is triggered further to actions that do not iterate  the representable (promote, rename, move...): thus even without copy over mechanism, the object keeps the old representation until the new one is generated.
However, if the queue contains a lot of jobs, it may take long before the new representation is generated; in the meantime the old, obsolete one is still accessible. Worst, if the publish job fails, the old representation isn't flagged as out of date and there is no easy way to detect the failure when inspecting the object, nor to schedule a mass republish of the objects in this state: resubmitting failed jobs from the Job Monitor is the only solution.
The former is particularly sensitive if file synchronization is used to update CAD parameters mapped to Windchill attributes: job delay/failure may result in out-of-date information displayed in the title block (e.g. lifecycle state, approver). Think of the PDF shipped to an external provider...
Deleting the old representation immediately, at the creation of the new job, would avoid any ambiguity: the representation would then be either reliable, or missing. And catch up would also be easy, by scheduling republish of all objects without default representations.
Kind regards,
Giacomo Slavazza
PTC Principal Consultant
9 Comments
d_graham
Giacomo,
I agree with you. In fact, I have implemented solutions to do just what you describe.
If a new publishing job is created all the old Reps  (or at least the default Rep) gets deleted.
gprajeesh77
  Do you let me know how you implemented this in your environment?. If you can share some light on this, I can look into it
Best Regards
Prajeesh Kumar
ijones
We are seeing increasing issues with clogged and failing WVS queues ourselves and such functionality would be invaluable to Creo View users in ensuring the content they access is up to date. The OOTB Marked-Out-Of-Date and/or CarryOverRepresentations=false functionality is insufficient to set up a well-configured system.
It really seems as if this should have been OOTB functionality for Windchill for a very long time.
@d_graham I wonder if you have any detail on the implementation details for the above?
d_graham
@ijones
Are you referring to cleaning out log jammed publishing queues or deleting old reps?
I can help with both.
How you are triggering the publishing now?
Publishing rules?
Workflow expression?
Something else?
My code is fired from a workflow and a bulk Drawing PDF download tool but whatever the use case it will be doable.
I’ve got an idea that should be bombproof regardless of how the publishing is triggered.
Send me a message with contact info. It’s easier to communicate via email than Back and forth with community posts.
David
RaviM
8-Gravel
Did anyone find an answer to this.
We do need an option to delete old representations when a drawing is sent for republishing.
Its not practical to expect users to chose the correct representation to view or download the PDF representation from.
d_graham
@RaviM
As I mentioned in my post I’ve been deleting the old reps automatically.
It does require custom code but the code. The utility I wrote has worked well and seems to be bombproof.
I’m not aware of any OOTB way to do what you’re asking.
RaviM
8-Gravel
@d_graham
Thanks. I guess I will also have to develop the custom utility to do this.
ideally, these should find ways into the product as improvements
d_graham
If any one is interested in automatic delete of old reps every time a new rep is created feel free to reach out to me for help.
This can be set up such that the reps are always deleted automatically or the delete can be turned on/off with a preference.
The advantage of using the preference is that you do not need to stop/start Windchill to turn delete on or off.
David
AP_10324049
3-Visitor
@d_graham
Can you please share the Utility code to republish the CAD Objects ?
