Give the business administrator the capability to define the configuration specification used by the BOM_RELEASE_RULE business rule for collecting dependent objects. Currently in 10.1 M010 the "Latest" config spec is the only one available. At Steelcase (with this config spec) the rule would fail a large percentage of the time.
