Currently (10.1 M040), when the BOM release rule fails, the resulting item is displayed in the conflicts table but the offending object is not given. This results in a wild goose chase to find the offending object. In some cases such as an EPMDocument that References another EPMDocument this can be quite time consuming. To reduce the time, an administrator can set the com.ptc.core.businessRules.validation.BOMReleaseRuleValidator logger to DEBUG and ask the user to Resolve Conflicts to run the rule again. This will produce the below messages in the error logs. An admin can then search for the offending object using the object id.
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - Collection component insatnce is:com.ptc.core.htmlcomp.collection.engine.CollectionComponentInstance@48dbecd5
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - The config checkPredecessorRevisions is not set, defaulting to false
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - The config checkPredecessorRevisions is set to false
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - life cycle states are:RELEASED
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - Lifecycle state is:RELEASED
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - Life cycle managed states are:[RELEASED]
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - config: targetState, states: [RELEASED]
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - config: validDependentState, states: [RELEASED]
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - Life cycle managed states are:[]
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - config: invalidDependentState, states: []
2015-10-14 14:55:01,007 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - Transition is:PRODUCTION_RELEASE
2015-10-14 14:55:01,008 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - changeables are:[wt.epm.EPMDocument:2138118520, wt.epm.EPMDocument:2138111271, wt.part.WTPart:2138119466]
2015-10-14 14:55:01,011 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - lifecyle map is {wt.epm.EPMDocument:2138118520=RELEASED, wt.epm.EPMDocument:2138111271=RELEASED, wt.part.WTPart:2138119466=RELEASED}
2015-10-14 14:55:02,064 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - Life cycle state is:CREATE
2015-10-14 14:55:02,064 DEBUG [WfPropagationQueue.PollingThread] com.ptc.core.businessRules.validation.BOMReleaseRuleValidator wcadmin - The dependent object wt.epm.EPMDocument:1578421365 is not in a valid state: CREATE
Please add the offending object in the conflicts table when the BOM Release Rule fails!!!
