Be able to deploy Java code in Windchill without having to restart the server
Almost all modern applications are now able to deploy java code without having to restart.
With Windchill you still need to restart your server to push a java update, or declare a new listener.
We need to be able to push java code without any restart
6 Comments
STEVEG
PTC has started removing Java from Windchill and will continue to do so.  It doesn't seem like it will matter anymore?
MorganBelais
Hello Steve,
I'm talking about Windchill customization java code, not the applet side.
So unless everybody stops all customization it is still necessary
STEVEG
Ah.  Got it.
MorganBelais
Please PTC, if there is no short plan on this one, can you at least try to contact companies like Jrebel ?
JRebel Java Plugin: Eclipse, IntelliJ, NetBeans | zeroturnaround.com
Their solution is partially working with Windchill, if you don't have PSM agent.
joelorona
3-Visitor
Any updates on this topic?
olivierlp
Community Manager
Status changed to: Archived
