The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Be able to extract information/metadata from PVS files in the database.
It would be useful to be able to list and extract metadata out of PVS files.
For example, I would like to list all representation (viewable) with inconsistencies between PTC_WM_LIFECYCLE_STATE and epmdoc_lifeCycleState.
inconsistencies between PTC_WM_LIFECYCLE_STATE and epmdoc_lifeCycleState.jpg
3 Comments
sully7
Nicolas,
This is possible using the Creo View Toolkit API.
More info here - https://community.ptc.com/t5/Customization/How-to-download-creo-view-toolkit/m-p/117148#M1167
https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=DVV
Feel free to reach out if you'd like more information on this.
James Sullivan
CadActive Technologies
cpadmanabhuni
7-Bedrock
Hi Nicolas,
I am not sure about OOTB capability without customization.
If customization is a valid option for you, either it can be done using Creo View toolkit as James mentioned or you could also develop a server side customization. There is a pvschange.exe (part of Viewable compression utilities) that can convert PVS file into a XML file which contains all necessary information. So using customization, download the file, convert it, read xml and identify any mismatches. May be this helps.
https://support.ptc.com/WCMS/files/172773/en/MCADAdaptersInstallConfigGuide_en.pdf
olivierlp
Community Manager
Status changed to: Archived
